1 members (Scott35), 195 guests, and 26 robots.
#111240 10/02/06 08:04 AM
From Michael Cash
These pictures were taken when a homeowner called me and said her boyfriend rewired her pool equipment. She wanted me to come and take a look at it. I didn't know garden hose was an approved conduit to run wires through.
Let's see, we've got water pipe, a garden hose, now all we need is water in this mess to fill it up. (At least I think it's water pipe.)
Ohh, there's wires in them pipes! [Linked Image]
Okay, I know we've seen garden hose as conduit before,but I can't find the thread. Water pipes/fittings and garden hoses, I guess he was a "Two wrongs make a right" kinda guy.
Ian A.
[Linked Image from anti-aol.org]
I don't recognize that white 90 in the last photo. It looks like there are three holes in it along the vertical axis. What is it? Another custom part?
I have to say that it's a first for me to see garden hose used as conduit...but I'm a young punk....
RSlater,
RSmike
That 90" fitting looks like something we had on our jacuzzi " bubbler" for the pool.. It was an air inlet of sorts... Could also be the spout off a chlorine jug too.
The holes in the white fitting are for heat dissipation.
Now that is the reason I hate selling to homeowners. They won't spend the extra money on the proper fittings. I do have one question though. When did the weep hole for a panel become a wire entry?
Allen
Bob you took my line! LOL
Ian A.
At least he provided some mechanical protection, I have seen worse.
He is certainly is not a tradesman.
It looks like that the green earth wire in the last picture doesn't continue in the grey pipe.
that green wire might just be a really bad pull job. I think that it is just looped there. Regardless, this should just all be re-rewired to make it less awful.
The garden hose idea isn't that bad, however, provided that it is for low voltage and temporary use only. I have a fiber cable run inside a garden hose that I use for really long runs where twisted pair wouldn't work. I use it a lot for outdoor concerts if were streaming audio on the web. It is only for temporary stuff, though.
