227
13
I was called to a fleabag hotel, answering a complaint that scatterec receptacles were not workng. I found many, many outstanding examples of what happens when electrical work is performed by untrained, ill-equipped persons.
In these three pics, I am focusing on a common theme: poorly run conduit that has come apart, probably due to a complete lack of support.
[img]https://www.electrical-contractor.net/forum/RS/550Alejo's_open_pipe.jpg[/img]
[img]https://www.electrical-contractor.net/forum/RS/550Alejo's_2nd_open_pipe.jpg[/img]
And my favourite- a pipe, thinly covered by a film of loose dirt. This is a time when I found the problem by literally stepping on it- the pipe had cut into the wires, and sparks followed.
[img]https://www.electrical-contractor.net/forum/RS/550Alejo's_ground_pipe.jpg[/img]
Oh, the 'three strikes?' Poor workmanship, no support, conduit not continuous.
[This message has been edited by renosteinke (edited 09-14-2006).]
Umm John, Is this a hotel for little people?. Reason I ask is because of the hieght of the meter and it's proximity to the roof. Maybe it's the angle of the shot.
Good catch; that meter is easilt 7 ft. up. I will post another pic later, where the panels will be the "star" of the show!
Gasp. I can't wait to see the panneling. I bet its very, um, in keeping with the rest of this.
Wow...I am truly amazed to see wiring like this at a fleabag hotel. And here I was expecting to see perfectly plumb PVC coated ridgid. What was I thinking??
Peter
Peter
Posts: 869 Likes: 4
That's a clock dial too!! The meter reader must have good eyesight or uses binoculars. or he is very tall
In parts of Texas and Louisiana, I have seen a number of meters that are mounted as much as nine feet or higher above the ground. Is there any particular reason for this? I can imagine the meter reader having to carry around a periscope to be able to do his job . Mike (mamills)
