390
14
Posts: 3,682 Likes: 3
Administrator Member
How can someone put so much effort into something like that, Rube Goldberg would have been so proud!!! It looks like these were used receptacles that were either from a split kitchen circuit or several individual switched outlets. Did you find this in a business or a residence???
residence. also,no grounds on either one.
[This message has been edited by Wizzie Electric (edited 09-05-2006).]
Thanks.
Of course theres a ground! Theres a chassis, right? People don't realize just exactly how much power computer equipment can draw. Its crazy that someone would even try stuff like this, espescially when you can get commercially made powerstrips for so little money. There is a hardware store near me that sells really nice ones for $5.00 and not as nice but better than this contraption ones for $1.25.
50 points to whoever gets this one right:
On the first pic, the straps and screws holding the outlets are from what? There are two possible answers (that I know of, anyways)
Hint: The screws are allen key and the nuts are square.
Posts: 869 Likes: 4
Posts: 869 Likes: 4
The screws are certainly not Meccano. These were usually brass slotted screws, I think they were 5/32 or maybe 3/16. The set I had had hexagonal brass screws. The original Meccano strips were green while the plates were usually red.
Then I had TEMSI which was a German variant of the English Meccano, which fitted with the Meccano parts OK, although the finish wasn't as good especially on the shafts which were perhaps a few thou thicker and some gearwheels didn't fit on them. The colours of the latter were different too.
The 8 way power botch has no ground at all, the lead feeding it is only 2 core.
[This message has been edited by RODALCO (edited 09-06-2006).]
The silver stuff with the hex key screws and square nuts was later, maybe in the mid 90s, I forgot the name, but I had a tractor set somewhere.
Did anybody else notice that on the "outlet strip" they took the time to cut the jumpers on the side connection and put jumpers in on the back stab?
