506
19
Posts: 3,682 Likes: 3
Administrator Member
On an air force installation the government saves money by running the comm. cables and water in the same pipe
Arturo Perez CMSJV, Construction Inspector (edited to insert correct pictures) [This message has been edited by Webmaster (edited 08-18-2006).]
oops! wrong pictures originally posted. Got it right now ...
I don't see any water. Oh.... that water.
That's the new liquid cooling system for conduit. You can run wires 250% above NEC 310.16 as long as you keep the conduit full of circulated H2O; it's going in the next code revision.....
Seriously....our government....saving money. Come on really where is it?
RSlater, RSmike
Posts: 794 Likes: 3
I see what looks like coax BNC connectors in there. One thing is that coax cable quickly goes bad if water gets inside of it. Coax cable is used for high frequency signals (cable TV, high speed computer networks and such) and water severely attenuates such signals when it's inside the coax. All that coax is sure to be bad, and will need to be replaced after the source of the water is corrected.
I maintain a building where we have many direct buried runs that have been "hacked" in over the years. We have had to replace many bad RG6/8/59 cable runs due to them rotting in the ground as well as other issues. We had a maint. tech a few years back who ran wires to another building by fishing them through a storm drain
My father would love that job. Ian A.
Co-ax is terrible as far as moisture is concerned. I once chopped out a piece from a job a few years back and all though the piece was only 6-7 ft long, I got a cup of water out of it.
