390
14
Posts: 3,682 Likes: 3
Administrator Member
This was in a kitchen remodel at a church. The plumber installed a water heater under the sink and instead of having an electrician put an outlet where it was needed cut a hole in the sink lip and ran his cord through it. There is no grommet or other protection where the cord goes through the metal.
Alan Nadon
Man oh man... that is one classy install.
I suppose it could have been worse. He could have tried to run it down inside the overflow!
I suppose it could have been worse. He could have tried to run it down inside the overflow! ~pauluk ------------------------------ Such a sink doesn't have an overflow, but at least there's a GFCI.
...and it's only because of the intellect of the electrician (and maybe the NEC)that the GFCI is there to begin with (although locating a receptacle of any kind directly behind a sink doesn't seem like a great idea).
Unfortunately, it seems that a lot of church installations are done by well meaning but seriously misguided people - usually on a volunteer basis.
Must be another US thing - in Europe I've yet had to see a sink without an overflow.
I guess the receptacle was there before the sink...
If I had to guess, Texas, I'd guess that this kitchen was re-modeled. I suspect that the original sink was a single basin (to one side of the receptacle), and that the cord goes to a garbage disposall under the sink. (How the disposall is switched is anyone's guess!)
Maybe.
As far as the handwriting on the picture goes the cord supplies a water heater.
Texas, you're right! I must have been having a "stupid" attack! OOPS!
Church remodel? Ah Ha!!!! There must have neen a reason so I think that I know the answer. Either it's a means for one to meet his maker or a way for one to have a "born again" experience.
