by NORCAL - 03/19/24 05:11 PM
0 members (), 260 guests, and 19 robots.
Page 1 of 4 1 2 3 4
I have a couple of reasons for posting this pic....but first, I thought I'd give everyone a crack at it!
- renosteinke
Is that just regular PVC conduit that's been bent to shape?
The 90 degree fitting at the unit suggests to me that is liquidtight flexible conduit not PVC.
I don't see any issues unless there is no outlet within 25'.
Is the thermostat wire in the sealtight? I can't see it.
That is liquidtight, and not PVC.
Do you know what's the story on all those drain lines (?) on the wall?
There's no guard rail to that drop behind the far unit, [yet?]. I take it power and control circuit cables enter within the insulated refrigerant lines? Is it usual to put them both in the same insulating sleeve in the US? Freezing condense? Clearance side and rear looks ok, but I would have mounted the units higher for possible snow entry problems - I see some frost now. Bit exposed there to wind too.
And, is that a gremlin peering out from just below the 'liquidtight' in the foreground? [Linked Image]
grammar/spelling.
[This message has been edited by Trumpy (edited 03-24-2006).]
The liquidtight appears to encroach into the workspace for the disconnects.
(BTW), where's the control wire?
Hopefully, 24V control wiring is not in disco too.
Adding that the sealtite could use better support and routed as not to be as likely to be stepped on.
[This message has been edited by NORCAL (edited 03-14-2006).]
Isn't there a workspace violation for the disconnect on the unit further away in the picture? Like the unit is right in the way?
Page 1 of 4 1 2 3 4
