#110213 03/06/06 11:39 PM
Here is a neon sign transformer, not only exposed to the weather, but, since the cover is missing, actually "sitting in a bucket." Well, what's a few thousand volts running free?
- renosteinke
#110214 03/07/06 09:36 PM
Is that roofing actually metal siding??? [Linked Image]
#110215 03/08/06 07:12 PM
Absolutely unbelievable John!. [Linked Image]
Also consider that after a decent shower of rain or two, the water is going to fill the other enclosures as well(to a degree), through the conduits.
Some people should just stay at home. [Linked Image]
[This message has been edited by Trumpy (edited 03-08-2006).]
#110216 03/08/06 08:08 PM
"Liquid cooled".... Only when it rains though.... [Linked Image]
#110217 03/17/06 06:44 AM
K
Maybe its been disconnected?
#110218 03/17/06 07:57 PM
Resembles what you/I see after a sign repair. Also, the aftermath of an install by "the professional sign contractor"
We had a rash of neon signage and outline lighting that would magically 'appear' on Monday mornings. IE:
Stop at a conv store for a drink, next store has neon outline ltg, and signage inside of store windows. Wasn't there last week?? No permits issued. Worker said "boss not here";
$ 500 Violation (Fine) to storekeeper. Guy won't give up the installer!
Quite a few 'others'
#110219 03/17/06 09:18 PM
I'm constantly amazed at how many folks don't realize how dangerous neon signage can be. I worked at a local amusement park who had five! fires on the roof of one building caused by faulty neon installation before they gave up and went to another lighting method.
The HV output of that transformer will merrily arc to any nearby uninsulated surface until the ignition point of that material is reached.
Although the transformer itself is potted in a tar-like compound and could probably survive sitting in water without harm, (and I have seen that before too) I'd bet the connections to both line and secondary aren't that watertight.
Stupid should be painful.
#110220 03/19/06 01:17 PM
Our large facility had a neon sign fire on the exterior of the building. Of course, four circuits of transformers, two floors up from the panel feeding it with no local disconnects. Also butt splices, and ring crimps on 15, 7.5 and 5 kV leads. Another fine professional sign installation.
#110221 03/19/06 10:59 PM
Aren't local disconnects required by Code? If so, then it sounds like this "professional sign company" better have its liability insurance paid up!!
