516
17
Posts: 3,682 Likes: 3
Administrator Member
Spotted this one in a hotel in Decatur, IL last weekend. Yes, that is a sprinkler head next to the ceiling fan. Not sure if it's the firefighter or electrician who's more concerned!
- DougW
Wow, I can't believe this was the original install!!! Ceiling fan must have been an addition. My fire inspector friends will like this.
Larry LeVoir Inspector City of Irvine, CA
nice and cozey. that sprinkler isn't for the fire supression system its for a misting system on hot summer days
Thanks.
Well, in case of fire, that spinning fan will help whip the water around a wider area.
And when the power fails, the water jet turns it into a turbine so they can keep the bar open during the fire.
Alan - sad part is, this was in a guest room. I could understand a "party room", but...
You know it even looks like the sprinkler was tweeked a little to install the fan
Posts: 794 Likes: 3
Tweaked, it looks like that sprinkler head was pushed aside a good 8 inches to make room for the fan. The pipe feeding it must have had enough flex to bend a little. The body of the fan motor probably hides a slot cut into the sheetrock to allow the sprinkler to be moved aside. With that level of care exercised on this install, I would wonder if they used a proper electrical box for the fan....
the other condersing that with celing fan if the motor do "stall" it will build up a bit of heat there just enough to pop the spinker head off [ most will pop open at 135 F temp]
and who ever came up with this set up have not see the major goof there i dont know where the code but it should be in some kind of distance between the " object " and spinker head.
merci , Marc
It's in the NFPA Standards 13R-1999 According to CA Building Code & I don't have a NFPA Standards book. Anybody out there that can look that up?
