Run a separate EGC!
Many years ago I used to use EMT as the EGC. Unlike some folks I have had the misfortune to work with I was (and still am) always careful to tighten every connector and coupling. All that comes to naught when some inept remodeler (siders, roofers, whomever) decides to pop your straps and never puts them back. If you are using rigid or IMC you need not worry, but with EMT gravity will take its toll and you will no longer have a ground path. When this happens you will probably not be around to defend yourself or put it right. You probably won't even know about it.
For the last 8 years I have lived and worked in a jurisdiction where separate copper EGCs are required, but even if I had the option I would use a copper EGC. It's cheap insurance!
[This message has been edited by yaktx (edited 11-11-2005).]
