#109346 08/18/03 11:52 PM
This Meter installation is in the same town I live in.
We have a Town electric company and a Electrical Inspector, I am surprised it was approved.
It does not appear to be very old and it is at a major intersection, so it could not have been done without inspection.
The top meter must be about 9' above finished grade.
Bob (iwire)
#109347 08/19/03 12:01 AM
ROTFL.
Could it be that there is a remote system for reading the meter?
#109348 08/19/03 06:45 AM
Actually the municipal electric department is about in the middle of a 2 to 3 year project to change the meters to a remote read type.
Mine has been changed and these ones may have been updated too.
At the time this was installed I doubt they where thinking of remote read meters.
I think The electrician had no imagination on how to mount to the stone foundation, also the load side of the meters must all be exiting down low on the back of the meter pan to go through the sill into the basement.
Around here most inspectors want OCP no more than 5' feet inside before requiring an outside OCPD, so the panels must be right behind and below the meter stack.
The installer should be embarrassed every time he goes by this.
#109349 08/19/03 07:07 AM
At least they installed some rocks for the meter reader to climb up.
It could be a new sport---
Extreme Meter Reading
Actually, as Thinkgood mentioned, I believe most meter reading is done remotely these days. Not that this justifies the installation.
#109350 08/19/03 09:50 AM
Could the building have been jacked up after the meters were installed? the rocks don't look original to me.
tw
#109351 08/19/03 10:00 AM
Bob,
Is this fed with 2 sets of conductors? Are those SE cables or conduits coming out of the top?
#109352 08/19/03 10:31 AM
TW, The stones look funny to me too, the stone might be just a veneer that was added.
The height is unchanged as on the front side you take one step up on to a porch then perhaps one more to enter the first floor.
Hard to tell here but this is on a grade that is at its lowest on the side we see.
Bill, I do not know, I will look next time I go by which is often.
Bob
#109353 08/19/03 06:53 PM
K
How would you attach to the stone siding?
#109354 08/20/03 01:42 PM
I stopped by and walked right up to the service, it is Parallel runs of 1/0 or 2/0 SE AL Service Cable.
I am 5'-8" and on my toes I could put my fingertips on the center meter.
Kale
I would probably mount a piece of pressure treated lumber the size of the meter socket to the stones.
My first thought would be to get some epoxy anchors to put in the large stones to mount the lumber.
We have put site pole studs in the concrete base with the right kind of epoxy.
Bob
#109355 08/20/03 02:07 PM
Maybe they lean out the window to read it?
