220
12
Posts: 3,682 Likes: 3
Administrator Member
This customer was requesting us to connect there Over Head service on a new two story house. NOT...we laughed when we pulled up to run the service and we saw this. Wait till the city comes out to issue a clearance... (J.C.)
Posts: 4,116 Likes: 4
This is a pretty unusual looking setup! I don't think this setup would last too long if it was hooked up either. People don't realize how much tension there can be on the point of attachment of an overhead service. Bill
I don't know how long (heavy) the service drop will be, but if the support was attached to the house instead, there should be no problem. Among other things, those LBs look to be aluminum, I wouldn't think the hub would hold up to any appreciable weight. As shown, the conduit would probably be considered a mast. In that case, it should need to be at least 2" diameter and installed with approved mast fittings.
As ugly as this is, other than the violation that Redsy pointed out what can you say? Move the point of attachment and it's is all set. 230.28 Service Masts as Supports. .......Where raceway-type service masts are used, all raceway fittings shall be identified for use with service masts........
I'll bet those extra long pieces of green strut would make enormous rust marks on the side of this place in no time...S
Seems like any tendency for the triplex drop to twist might unscrew the LB and lay the 12-inch “riser” on its side.
i allready see it before on one place and it did actally rip the LB right off and i have to repair it and deletes all the LB fitings and redo it propely if i see it again i will make sure the service mast insluaters are off the conducts btw if they are 2 inch rigid maybe can use but i doubt as i see the picture and someone dont relazie that the constant tenson can pull it off over the time
merci marc
Looks like the fence could be 6'high, The top of the meter base appears to be about the same height. So...is the weatherhead at about 8'??? Also, the elbows make a handy spot to tap into after the POCO is gone.
kduke
I noticed both Marc and Redsy made reference to 2" raceways for masts, where is this from, all I see is listed for mast use and of sufficient strength.
Is there another article or local codes that are being referenced.
Not that a 2" minimum size is a bad idea.
Bob
Bob, the poco in my area,and most I,m aware of,won't "hit" as we say here,anything smaller than 2" rigid.
Our poco insists the mast be used as the support for the service drop. They won't tie to the structure anymore.
Of course,an overhead service on anything but a commercial building is almost a thing of the past here.
Russell
