Electricians revenge
1 members (Scott35), 152 guests, and 14 robots.
#109231 08/20/03 09:27 PM
these are some pictures of different job locations, which fall under the insufficient clearance heading.
- richard
Thanks richard! [Linked Image]
[This message has been edited by Webmaster (edited 08-20-2003).]
#109232 08/20/03 09:53 PM
That would be real comfortable adding a circuit to that panel while resting against the grounded steel tank. [Linked Image]
#109233 08/20/03 10:08 PM
Z
You just need to use cowboy approach to "mount" yourself onto the oil tank.. lol
Funny thing, oil tank looks like it's been there forever, that panel does look *THAT* old though, either does the wiring coming out of it, i'd guess mid to late 80's for the panel and like, original to the house oil tank.. so one can only guess it was an un-inspected subpanel that was added later.. and the mains is somewhere else
#109234 08/21/03 03:04 PM
I've seen someone go one step further by putting a wall up in front of the Oil Tank and just having a small access door (smaller than the panel) to reach through.
I wish there was a way to teach the other Trades about this kind of thing. [Linked Image]
#109235 09/10/03 09:31 PM
The first image looks like that equitment was installed after the oil tank was installed, so the electrical installer would be at fault.
#109236 09/12/03 09:06 PM
That is the problem with homeowner joe, or his "buddy" doing work that is better left to someone with experience and a licence. I was at both locations for service calls, and i see this all the time. It really is a shame
#109237 09/14/03 02:34 AM
To rub more salt into this wound:
And what about whoever it was who installed the TV antenna cabling there?
The splitter and some of that coax is hanging right over that panel...not to mention it's nicely resting over the sharp flange of that box.
#109238 09/14/03 07:51 AM
It looks as though the coax was cut a little too short (look at the cable going up into the ceiling to the right) and someone just pulled this messa cross the panel to make it reach.
Building a cupboard around electrical panels is a favorite trick here. I've seen some where the "access" door somebody has left is so small you can barely get your arm in to open a breaker. [Linked Image]
