Sparked: You are right about the GFCI slots with decora receptacles installed (they're a lot cheaper, you know!!!).
The close up receptacle ground probably couldn't allow a ground pin installed, but you want to anyway...that isn't a shadow in the corner it's a gaping hole in the receptacle!
