1 members (Scott35), 636 guests, and 18 robots.
#108094 05/31/04 07:44 PM
I do not belong to any of the electrical forums, but lurk there often observing the codes and pics for discussion. I thought the following pics I ran accross in the last week may be of interest.
Timm Phillips
Note: Timm, Join up!!...S [Linked Image]
#108095 06/01/04 12:32 PM
Maybe the cover was left off to provide extra cooling airflow for when the un-protected feeders are overloaded? [Linked Image]
Good pics Timm.
#108096 06/01/04 01:32 PM
Good pics of some pretty sad looking stuff!
The meter & riser are obviously moved for some sort of remodel project, but a 30" riser??? Did the Poco use a telescope to read it, or was the triplex seriously low to the ground???
The rest looks like a nightmare! The main panel, I'd make a guess, you had to move a bunch of stuff to get to.. The spiderwebs & lack of cover usually means this thing wasn't touched for many moons! [Linked Image] (not that you should touch it without a flash suit & face shield!! [Linked Image] )
Cmon & join up Timm! I was shy at first as well, but I've made soooo many friends & contacts since I joined here!! No question too simple, no question too hard! (yet at least! [Linked Image] ) Hope to cya on soon!
-Randy
#108097 06/01/04 09:15 PM
Meter and mast have not been moved, they are in the original position, one that has been in place for well over 20 years.
We are in the process of adding to the river cottage turning it into a home.
BTW...they have had a hot tub that grandpa installed from that far end illegal 60 amp panel stuff. No ground!! But they did have a GFCI on it.
Timm
#108098 06/02/04 10:38 PM
It looked like some sort of horribly cobbled temp service at first.
Once I realized it was a regular service, I'm amazed that the PoCo let it go for so long!
Thanks for the pics!
#108099 06/03/04 07:34 AM
Here are some more from Timm
here are two more related pics.
One is a pic of the meter on the side of the house as of 18 months ago when the project started.
The other pic is the replacement panel installed at the location of the original mains, after we moved service to the far side of the new garage and made the old panel location a sub panel, It was upgraded to a nice new panel, and we put the two panels at the far end of the house on a 50 amp breaker, and added a ground wire to them (not shown)
#108100 06/03/04 12:07 PM
Great pictures Timm. Welcome aboard. This is the friendliest bunch of people here that I have ever met. [Linked Image]
#108101 06/06/04 09:14 PM
Hey Timm,
Welcome aboard!. [Linked Image]
I must say like the Neutral and Ground ID's in the back of that last panel shot!
#108102 06/07/04 08:58 AM
I like to label sub panels like that. I find even lots of electricians forget they are wiring the furnace or whatever to a sub panel.
Timm
#108103 06/07/04 09:14 AM
Hey Timm?
What is that word behind the two phase wires?
