#107992 06/25/04 03:37 PM
Behold the invention of a homeowner to avert buying an 'expensive' $10 in-use cover.... & then something that could use a bit more than a new cover.....
-Randy
#107993 06/25/04 05:00 PM
Does the shed also make it an indoor non GFCI location?
What's the gizmo on top? An invention to avert buying a sprinkler control?
Did the bell box have busted-off-screw-in the-box-itis, too?
#107994 06/26/04 11:58 PM
Scott,
In typical South Orange County style, the GFI is in the garage, protecting 3 bathrooms & this mess, so at least there's that to be thankful for...
The wall-wart on top wasn't wired to anything, I'm assuming there used to be a timer here, due to the bank of sprinkler valves..
What Bell box over 10 years old doesnt have that if you try to change a device?? The main reason I prefer to use PVC Carlon boxes where I can...
-Randy
