211
Posts: 3,682 Likes: 3
Administrator Member
A " field listed - homeowner approved " fan box. At least he did install a block for it...... An HVAC disconnect on the rear of a manufactored home. Came in BIG box with sizzor lift !!!!!!!!!!
- necbuff [This message has been edited by Webmaster (edited 07-09-2004).]
Is the A/C condensor being dual used as a back step/porch here also? The disco might even be considered accessible in that case -Randy
Eye level if you reach around from inside the door.
Timm
Is that an extension cord feeding the fan box?
That's 12/3 romex feeding that. As long as the screws that support the fan go into the wood I see no problem.
As far as i know this box cannot be used as a fan box, if the scews go into the wood or not. This box was not intended to be used for fans so, so i think using other than 10/32 screws in this bow would be breaking the UL listing.And yes that is 12/3 romex now yellow, used to be white a few years ago, about 3 or 4 yrs ago i think.
OOps sorry about the typos
The screws used for standard fixture boxes are 8/32 not 10. And suppose you mount the fan using the 8/32 holes and then you use the 3 1/2" wood screws that come with the fan to secure the fan to the framing member also. What is the problem?
