1 members (Scott35), 383 guests, and 13 robots.
#10742 06/17/02 08:33 AM
Eandrew Offline OP
Is cotta wall the same as cinder block?
#10743 06/17/02 10:16 PM
Terra Cotta is a red clay based material and I have seen block walls made of it. Generally cinder block, now just concrete, is the standard blocks you see the most. Hope this helps.
#10744 06/18/02 04:34 AM
Over here, terracotta is most often found for floor tiles or roofing tiles.
