559
20
Hmm, it appears we have
UG-Underground, now how about,
OH- Overhead.
Ian (Watch someone find OH in this thread) A.
CB - Circuit Breaker MCP - Motor Circuit Protector OL - Overload TM - Thermal-magnetic circuit breaker AIC - Ampere Interrupting Capacity V - Volt VM - Voltmeter A - Ampere AM - Ammeter WHM - Watt Hour Meter Hz - Hertz
BX CABLE: Term comes from the old Bronx Cable Company. When electricians back in the day used to order armored cable, it came in a crate marked "Bx Cable." It was short for Bronx Cable. This was the explanation given in a Thomson Delmar Electrical Training book and I believe it.
Whoa, Brown outs is badddd news. I work for a POCO and a brown out is most likely going to be a prelude to an outage. Low voltage will damage equipment in a heck of a hurry and needs to be corrected quickly. As the voltage drops, the current of course rises rapidly to maintain load.
The sound of an air conditioner or refrigerator running under voltage is enough to make me run to unplug/turn it off before the motor smokes.
Modern dispatch systems will warn of these conditions and it has become quite rare (around here anyway) to have a brown out last more than a few seconds.
Nuke Test/Smoke Test = Bringing a Service or Equipment on line. Customers love to here the electrician yell out "everybody clear, Nuke Test!"
Rob OK, lemme ask, where/how did you (or whoever) come up with "Nuke Test?" Ian A. [This message has been edited by Theelectrikid (edited 11-19-2006).]
So much lingo in electrical work…
Carflex – Liquidtite flexible nonmetallic conduit Jake – 90-degree conduit “inspection elbow” Acorn – Ground rod clamp for direct burial 1/4 Bend – 90-degree sweep 1/8 Bend – 45-degree sweep FA – Female adaptor MA – Male adaptor NM-B - Romex Stacker – Plastic spacer and support for multiple NM-B cables T&B – Plastic Romex connectors (Also a major manufacturer) SER – Service entrance cable assembly with L-L-N-G conductors SEU – Service entrance cable assembly with L-L-(NG) ATS – Automatic Transfer Switch AFCI – Arc Fault Circuit Interrupter Keyless – Simple porcelain or plastic lamp holder Twins – Tandem circuit breakers GDO – Garage Door Opener Rock Wool – Fireblocking insulation “Roxul” Fantech – Remotely mounted exhaust (bath) fans Hotbox – Electric heater used to bend PVC conduit Unibit – Any variation of a step-drill Faceless – Single gang GFCI device without receptacle outlets Soap – Pulling lubricant Nolox – Aluminum oxide inhibitor E-Y – Potable conduit fitting Jiffy Clips – 3/8 Trade size straps Handy Box – Small, single-gang metal device box Mouse – Foam Sponge used to vacuum or blow a pull line through conduit B-Caps – Wire nuts PLC – Programmable Logic Controller HID – High Intensity Discharge MCR – Master Control Relay PIR – Passive Infrared CO – Carbon Monoxide Detector (or Certificate of Occupancy) UPS – Uninterruptible Power Supply UTP – Unshielded Twisted Pair (Cat5e, Cat6) RG6 Quad – Common “Radio Guide” cable (cable television, satellite) Duct Seal – Nonhardening putty, usually grey RTV – Silicone sealant “Room Temperature Vulcanizing” Tapcon – Self tapping concrete anchors
[This message has been edited by Matt Barrett (edited 11-21-2006).]
