186
WARNING $1000 FINE UNSAFE INSTALLATIONS
In line with ORS 479.710, which states, “Electrical installations must meet minimum safety standards. (1) Except as provided in ORS 479.540, no person shall make, supervise or direct the making of an electrical installation which does not meet minimum safety standards.” As stated by John Powell, Chief Electrical Inspector for the State of Oregon, at the last industry meeting held September 14, 2004, unsafe installations would include connecting all breakers to the circuit conductors without a device on the end of the circuit. Any circuit that is energized or could be energized by turning on switches or breakers are considered unsafe and are subject to $1000 fine and suspension of license to the company/installer/inspector. At this time, the City of Bend will approve with exception any such installations. The responsibility of making any installation safe is up to you. But as of October 1, 2004, such types of installations will be denied. Thank you, Lukas L. Koomen, Chief Electrical Inspector Reminders: • Conduit straps not approved to support SE cable. • Two gang nail on boxes not approved for range cable. • Approved fittings required for 8/3, 6/3 cables for panel and boxes.
City of Bend Community Development Department Building Division Bend, OR 97701 [This message has been edited by Joe Tedesco (edited 09-15-2005).]
I used to put everything under a breaker and then tape them off until I returned to do the trim out. The new company I work for has a different policy and I think its better than the old one. Now when we tie in the circuits we put the breakers in but NEVER put them under the terminal until everything is in. Now I prefer this policy. My tool supplier, though, hates this policy because I dont "blow up" as many linemens pliers as I used to!
"My tool supplier, though, hates this policy because I dont "blow up" as many linemens pliers as I used to!" LOL Yeah, I think we all have a pair with a mysterious notch in the cutting surface!
Isn't that how you get wire strippers?
