1 members (Scott35), 536 guests, and 18 robots.
[Linked Image from images.industryclick.com]
So, this installation is fine as installed but as soon as the rock is placed it violates 386.10.4 and 386.12.5?
Mike Wescoatt
Are you allowed to bend that flat track raceway, or do you have to use a fitting?
That "flat track raceway" is called Wirewmold; and yes, you are allowed to bend it:
Question:
Is a bender available for the 500 and 700 series raceways?
Answer:
The 600B Bender is used to make bends, saddles and offsets in the 500 and 700 series raceways.
http://www.wiremold.com/www/commercial/tech_support/faq/faq_detail.asp?faq_id=37
...and you can buy one for $69.90 here: http://www.electricsupplyonline.com/prod/wiremold/600b_w003980.php
OR...
you could carefully use a 1/2" EMT bender - BUT, as EMT is round and wiremold is square your results may vary and the wiremold will more than likely show the tell-tale marks of an EMT bender having been used.
[This message has been edited by Celtic (edited 08-03-2005).]
~~ CELTIC ~~
...-= NJ =-...
