by NORCAL - 03/19/24 05:11 PM
0 members (), 265 guests, and 15 robots.
Physical Damage: There ought to be a law against this type of installation!!
[This message has been edited by Joe Tedesco (edited 11-28-2003).]
Do we really want to incite the "plastic v. Metal" battle again?
Break out the asbestos underpants!
There is a law against it Joe, it's called the NEC. [Linked Image]
Why are there two white wires (presumably the "neutral" wires) and only one "hot" wire? (Look at the larger conduit.) The green conductor has white tape on it, also.
and NM(?) coming out of the LB...
Steve
Really a poor glue joint on the larger conduit.
Physical Damage ?
I don't think so !!!!
This is clearly a result of "Mental" Damage...suffered by the installer afer he sniffed the glue he was supposed to use on the pipe......
...Despite all my RAGE,
I am still just a Rat in a CAGE !!!!....
The original installer should have complied with 352.12(B).
Don
Isn't that enclousure actually supposed to be bolted or attached to something so that it is supported by something other than the conduit? Where did that support go, was it every there?
Incidentally Don, what is the jist of 352.12(B)? On my next trip to the U.S. I will purchase a N.E.C. code book.
[This message has been edited by crash (edited 12-04-2003).]
I believe it should have been .12(B)&(C). In fact it is hard to tell by the picture, but the location may not even be suitable for this disconnect, it looks like a pullout or small disconnect.
Pierre
Pierre Belarge
