That orange extension cord is also missing the grounding pin.
Notice the round hole is up and the cap is oriented down with the flat side opposite where the ground pin should be.
So the whatever-it-is that's on the other end isn't even grounded!! You say it's a pump??? Oh man.....god forbid that thing should ever develop a short-circuit.
What does the user do when they need to use the hairdryer or the electric-shaver? Plug in a triple-tap?
