IT actually is just under the panel
Customer wanted to add Central A/C and a Spa on existing service
anywho, that wall pictured was invaded by honeybees and was all warped, Note the black screws I used to try to straighten out to the right of meter base. AHJ passed the service for reconnect.yeah, I hate bubbles. we do not have to use them here, the plug just needs to be weatherproof when closed. When POCO came back, they used same old service wire from pole. That old wire is actually paralleled feeding two houses with 200A services!!!
One of the POCO guys remarked "I Guess we will have to upgrade our wire pretty soon,huh?"
*NOTE* the old ate up neutral that was reused for new service. These guys are really "above the law" I guess
[This message has been edited by Sean WB (edited 10-04-2002).]
