506
19
A "switched outlet". This is made by Arrow, part #8668X. Stamped on the face of the receptacle and on the yoke, one can read "10 A. 250 V." The snap switch mechanism is two pole, single throw with a pair of brass terminal screw for the line at the top (as shown in the photo). As set of brass load terminal screws are on the bottom. I found the device connected to a 120 volt hot and neutral, but the load terminal screws weren't used for anything down stream. Al
Al Hildenbrand
Al; Thanks for posting the pic. of the switch/receptacle! I remember seeing one exactly like this many years ago in a friend's house when I was living in Denver. I couldn't begin to describe it because it was so strange looking.
Mr. Tedesco: I have attached 2 pictures. First is a junction box that has some loom-covered K&T coming into it via some ceramic "Federal Bushings" as well as some old BX. The second picture shows the splices inside of the junction box. This wiring has been taken out of service due to a leaky sewer pipe incident, which is a another story...I hope I can find the pictures from that one. Feel free to use the pictures as you see fit. All the best! [This message has been edited by Joe Tedesco (edited 08-07-2002).]
Gotta love those old ceramic bushings, insulators and tubes... Thanks for the pix! Mike (mamills)
Rubber and Friction Tape I found this in an old furniture store on the 3rd floor, and the splices look original and are probably like those we have discussed here.
Joe,
Just try to remove that splice to work on it. CRACK! I can hear the insulation crumbling beneath my fingers right now. You are left with 2 thin pieces of bare #14 ga wire. I have seen way too many of those splices in my time. Thank you anyway. (GRIN)
Caper
Joe: was it left uncovered/exposed like that when you found it? It also looks like there is some kind of "goop" in there with the wires. I assume this is still energized...
Like a pretzel for sure, and the cover was still missing and I believe the "goop" was probably floor wax!
Joe,
Is there a single gang floor box cover that is UL listed for this application? There is one that everyone uses however if you read the instructions, it is meant for show window floors only.
Caper
In Austria connections were either twisted or screwed with bolt and nut and taped with only cloth friction tape. (i also found band aid, installed by electricians!) BTW, does anybody know if that tape stuff is still available anywhere in the world? It was much handier than today's PVC tape.
