Joe, Here is something I found today that I couldn't resist sending you. I found this from a complaint given by the local power company. Now there are several violations here, not the least of which is the 10 AWG wire on a double pole 70 amp breaker, and the panel definitely needs to be changed because of deterioration. There are several others. This is a pretty poor situation. But the most interesting thing to me is the neutral wire terminated by the vise grip pliers. And this circuit was being used by the way. It was running about 200 feet to a travel trailer. I wonder what the voltage drop may be doing to affect the stuff in the trailer? The conductor is on top of the neutral bus and the vise grip is the connector. They could not back any of the screws out on the bus because of deterioration, and by the way, this is a main panel!
Thanks, Darryl Dempsey
[This message has been edited by Joe Tedesco (edited 08-17-2002).]
