524
15
Hello Joe: Here are some pictures of a 32 VDC lighting panel, that the owner wanted me to convert to 120 VAC because he was tired of maintaining the batteries. Instead I built him a power supply from a buckboost transformer, and 4 100 amp diodes on heat sinks. The system dates from the late 20's. I find your site to be very informative, and fun. Thank you. Trainwire,
Trainwire: Interesting looking old panel! I rescued a panel which looks somewhat like this from an old church that was built in 1926 and demolished about ten years ago. The panel was made by Trumbull Electric Manufacturing Co. It had two large knife switches (with cartridge fuses) at the top...one which fed a sub-panel for the sanctuary lights, and another for the pipe organ. One question...are those open fuse links at the top of the first picture (above the plug fuses)? Mike (mamills)
Mike: Yup, they are open fuse links. 90 amp ones I think. I have to go back and check. There are knife swtiches above the fuse links, I just ran out of picture to include them. You ought to see the voltage regulators and contactors that are on the other side of this system, right out of Frankenstein.
trainwire
Trainwire: What kind of application is this (i.e. service for a house, farm, etc)? Seems like I read somewhere that, in decades past, rural areas used 32 volt generators for a power source since they were so far removed from power company or REA lines at the time. I believe they also used battery powered tube-type radios. Installations like this have a great deal of historical value. Mike (mamills) BTW, judging from the condition of the slate behind the fuse links, it appears that they have been pretty lucky avoiding overloads or shorts to date!
Hi Mike, Thanks for your interest. This is the lighting load panel out of a Reading Railroad Co. business car, known as the "Paradise". When it was on the road, being pulled by the train, an axle driven generator charged the batteries, and powered the systems. When you where in the station, there were several tons of nickel iron batteries under the car to power everything. You also had the option, when at the station of powering the car from the station, at 240v 3ph! The car steward had to be well versed in the operation of the very early mechanical air condiitioning system, as well as the electrical system in the car, as you usually had three different sources, and things could get exciting if you got confused. The panel is mounted on a board with some sort of a asphalt based paint, which makes it look like slate. But you are right, I don't think those fuse links melted very often. Steve (Trainwire)
Posts: 4,116 Likes: 4
Steve,
If you have any other pictures like this and want to send them in with descriptions maybe we could put them in a 'nostalgic' area somewhere on the site.
Thanks Bill.
Sorry its been awhile, works gone crazy, and I haven't been able to get back.
I have, can get other pictures of "historic" stuff, If anyone is interested. I personally like the old stuff. Knife switches, steam driven generators, big meters. I have learned alot. Thanks for letting me in. Trainwire
Posts: 2,236 Likes: 1
Those old panels were works of art... I still need to get to the Lowe Motor Inn in Point Pleasant, WV to get some pics of the panels there. Very similar, but with fuse-wire instead of fuses. Neat! Also, the covers are glass, so the innards are visible. Tom, do you ever get to Point Pleasant? Anyone from Ohio live near there? Maybe somebody else can take a look-see too? [This message has been edited by sparky66wv (edited 03-31-2002).]
Hi, Steve: YES!! Please send some more pix when you have the time. Virgil is right...these old panels are really works of art (as well as darn near bulletproof). If I can ever figure out how to use my daughter's digital camera, I'll try to post some old panels from my collection. Virgil: I'm disappointed!! Looked at the Lowe site and not one picture of those panels (guess they don't know what's REALLY important...just kiddin' of course). Hope you can get back there in time to take some pix before they upgrade... sounds like they're headed that way. Just hope they don't "upgrade" to FPE! Mike (mamills)
I did some small electrical work in an old theater not long ago that the front part has been remodeled into office space but the back part of it still had the old low voltage stage lighting equipment still there and looked just like this and it had some of the old monsterus dimmers too all though not energize any more but still intact. will see if I could get over there and get some pic's
Be Fair, Be Safe Just don't be Fairly Safe
Hurk: The dimmers you are referring to are probably old resistance units which were introduced in theaters back in the 1920's. These things had the unique capability of dimming D.C. as well as A.C. Loads (since some theater districts in large cities only had D.C. current...more modern day devices can only use A.C.). The common method of installing these guys involved mounting them sideways in a heavy steel frame along the top edge of the actual "switchboard" itself...a large vertical piece of marble, slate, or some other electrically non-conductive surface fitted with dozens of knife switches and fuses. The moveable contact arm on each dimmer (for imposing the required amount of resistance for dimming lights) was connected to a rack and pinion drive handle which was placed within reach of the board operator. Since the dimmers liberated large amounts of heat during operation, this elevated placement got them out of the way where they would not burn someone or start a fire. Since these boards were practically indestructible, it is possible that some may still be in operation, albeit at a tremendous risk of injury or death to anyone using them. I am very interested in equipment of this type because of it's fascinating historical perspective, and would appreciate seeing any pix you can send along. Mike (mamills)
