1 members (Scott35), 485 guests, and 13 robots.
#102848 02/03/07 12:45 AM
RobbieD Offline OP
Just a question about motors. What is a two phase motor? I have installed single and three phase ones but I have always been curious what 2 phase motors are and where they are used.
[This message has been edited by RobbieD (edited 02-03-2007).]
#102849 02/03/07 11:22 AM
#102850 02/03/07 07:06 PM
2 Phase Induction Motors were once the Industry Standard items - back in the early 1900's.
The 2 Phase Polyphase AC System was used in many areas, and was derived either solely from 2 Phase 4 Wire Distribution, or from 3 Phase 3 Wire Distribution - which was the more common method.
Variations of the 2 Phase Systems + Motors sprouted into some currently used types.
Small Dry-Type Polyphase Transformers are connected as Open Delta "Tee", which was a very common connection technique for 2 Phase 4 Wire Systems derived from 3 Phase 3 Wire Distribution.
These currently used Open Delta Tee Systems range up to 15 KVA, with Voltage Ratings of:
* 480 VAC x 208Y/120V 3 Phase 4 Wire,
* 480 VAC x 240/120V 3 Phase 4 Wire Delta,
* 480 VAC x 240V 3 Phase 3 Wire Delta,
* 600 VAC x 208Y/120V 3 Phase 4 Wire,
* 600 VAC x 240/120V 3 Phase 4 Wire Delta,
* 600 VAC x 240V 3 Phase 3 Wire Delta.
There are also 2 Phase 3 and 4 Wire Servo Motors in use today, for AI (Robotics) and related applications.
Scott35
#102851 02/03/07 09:48 PM
RobbieD Offline OP
Thanks for the answers. I understand what they are more now. I guess they are motors that use two different phases so they don't rely on a capacitor for the phase shift like single phase motors. I just never saw one before and was curious to what they were all about.
Thanks again.
#102852 02/04/07 02:43 AM
Forgot to mention:
Check the Technical Reference Section, for Schematics and some details regarding 2 Phase Motors + Transformer Connections.
Refer to the Menu For Technical Reference Area https://www.electrical-contractor.net/ubb/Forum15/HTML/000064.html
For links to the 2 Phase related pages.
Scott35
#102853 02/04/07 05:53 PM
RobbieD Offline OP
Thanks Man!
