by ale348 - 03/29/24 01:09 AM
by NORCAL - 03/19/24 05:11 PM
Hi
I am a uk qualified / UK registered electrician.
With my wife being canadian, I am thinking of the possibilities of crossing the pond..
Naturally I don't expect to be instantly qualified in canada.
Are there any pointers to the way to get qualified?
Does each state have it's own regs ? or is there a counrtywide one ?
B.C. would probably be our destination.
Does anyone know where I could get hold of a copy of the current regs for canada/B.C.
Many thanks in advance if anyone can help.
Cheers
Jerry
( yet another Brit thinking of ' getting on a boat ' )
Here are some links for you
http://www.bcelectrician.com/who_can_do_electrical_work.html
http://www.itabc.ca/newBCresidents.php
Edit to remove stale link
[This message has been edited by dougwells (edited 04-07-2005).]
Hi
Many thanks for your reply & links
cheers
Jerry
Hi All,
just got hold of a book on CEC & B.C. amendments, for residential.
On my initial browsing, What confuses me is calculating service size rule 8-200, the example uses 240v , as does a few other calculations in the book, I thought all Canada was 110v, but the book is written & published in Canada.
Is there a mix of 110v & 240v ?
Cheers
Jerry
Canadian residential:
Single phase 110/240
2 Legs & Neutral
1 leg 110 to ground/neutral
2 legs 240 line to line
-Greg
Wheb calculating demand we use the 240 voltage divisor
Hi Jerry,
The following link will give you a fair idea of the power supplied to a typical North American home.
Hope this helps! http://science.howstuffworks.com/power9.htm
Hi,
Many thanks for the replies, all is clear now.
Cheers
Jerry
Hi All,
Finally we made it to Vancouver, Canada.
Any suggestions on reading material / books or tips for the IP/TQ exam , I apparently have to challenge it to become a BC electrician.
Cheers
Jerry
Hi Jerry Welcome to Beautiful British Columbia. look up PS Knights book 2 it has a sample exam and questions in it. http://www.psknight.com/
and this one http://www.bcelectrician.com/
