215
9
I've noticed that many of the "Home Inspection Reports" related to real-estate transactions recommend "exercising" circuit breakers on a regular basis. What are your thoughts?
Posts: 4,116 Likes: 4
Redsy, I've always thought the same thing and would probably bet that I've read it somewhere in mfgrs instructions or recommendations. I've seen a lot of times where someone will turn off their Main to do work (as recommended) and it will not reset, and I was thinking that 20+ years in one position in a damp basement can't be good for anything. Bill
I had heard some years ago of a UL requirement to 'mechanically' operate breakers manually but have never verified this.
I think it's a good idea to cycle breakers, maybe off and on a couple of times ar least once a year.
That just happened to me last week. I swung by a friends to demo a floor box she didn't want before the new carpet was put down the next day. I figured I could squeeze it in before my final at school the same night. Rather that trace out which circuit I threw the main. On my way out I turned it back on and wouldn't you know it, the thing would not reset. I don't know if it was from not being exercised or if it just broke. It did not sound to good inside.
Posts: 2,236 Likes: 1
Outdoor discos mounted below OH meter bases are the worst... Especially when SEU cable and a "WP" hub is involved. I tend to shy away from switching any mains unless absolutely neccesary.
*crunch*
does any body use nolox when you install a main or any other high amperage breaker on a buss that's aluminum. I have had many breakers fail because of this problem and have been using the nolox for some time. :Wayne
Be Fair, Be Safe Just don't be Fairly Safe
hurk— Be Careful. That may be a misapplication if using particle-bearing inhibitor or any substance on the spring-clip/stab end of molded-case breakers. Conductive particles in sticky paste may incite carbon tracking and breakdown if left in contact with {bakelite} insulating surfaces.
[This message has been edited by Bjarney (edited 06-03-2002).]
I've wiped a little nolox on meter stabs when I've had difficulty removing the meter.
CDS
Nicholson Ga
