Electricians revenge
1 members (Scott35), 51 guests, and 9 robots.
#101841 10/20/03 05:15 PM
What's the difference between A.I.C and A.I.R?
And what are the exact definitions of these acronyms?
#101842 10/21/03 06:40 PM
AIC (ampere interrupting capacity) and AIR (ampere interrupting rating)
AIC (ampere interrupting capacity) - The highest RMS symetrical current, at specified test parameters, which the device is rated to interrupt. Device must interrupt all available currents up to its interrupting capacity.
AIR (ampere interrupting rating) - The highest current at rated voltage that an overcurrent protective device is intended to interrupt under specified test conditions.
Tony Moscioni
Electrical Inspector
Electrical Safety Authority
#101843 10/21/03 07:05 PM
Thank you very much
