There is a fairly good description of fire rated suspended ceilings about halfway down this PDF
http://www.cgcinc.com/handbookAssets/PDFs/e/Handbook_12574_CP_C9.pdf It looks like you can get 2 hours out of the good one. (U/L P237)
edit;
I assume you all understand a bunch of fire rated stuff does not make a fire rated assembly. (just squirting red caulk around) It has to be assembled exactly as tested and all the parts have to be there per the design spec. We got a good pitch on this from the USG guys at one of the BOAF conferences.
They have a selection of their stuff at
http://www.usg.com/PerfRatedSysAction.do The link seems to be broken but if you open up the USG Products link it will get you there. Look at performance rated systems.
[This message has been edited by gfretwell (edited 02-22-2007).]
