225
Maybe it's just a hang-up I have with the way some of the codes are worded, and a tendancy I have for trying to apply logic to a legal document. If I have a room that shares a common wall, it's treated one way, but if I double that wall up for extra fire safety and move it 12" away, all the sudden NEC wants me to treat it completely differently, which I think is BS- a room is a room whether it's sharing a wall or 30' away and should be treated the same way. I see outbuildings as merely extra rooms associated with the primary dwelling, maybe I'm wrong- as noted, this is not exactly my realm of expertise... But I see the shop as a dwelling sub-unit ("living") and see no logical reason it should be treated any different than a dwelling unit.
[This message has been edited by SteveFehr (edited 02-22-2007).]
Posts: 9,930 Likes: 34
Steve, it all has to do with diversity of the load. In a dwelling unit we put a lot of things in the load calculation that will not usually be going at the same time. Certainly with a house full of people on Thanksgiving with someone in the shower, washer/dryer going, every light in the house on and the stove/oven going on all burners that 310.15(B)(2) table is probably not going to be "enough" but most times it reflects the actual diversity a dwelling will have. In the case of your garage/shop, you have usually overbuilt but the answer is just to protect your feeder with 310.16. If you are tripping that you probably underbuilt the feeder.
Tom, you said the panel agrees it is only for feeders carrying 100% of the dwellings diversified loads. So what about a circuit to the garage? If you have a detached garage (with electric) the table won't apply?
I was thinking when you said shop, that maybe you meant a business of some sort. Of course if you are making kitchen cabinets in your garage and selling them, it is a business, right? Of course if you give the cabinets away then it's just a hobby.
I'll have to make sure our zoning officer checks the wiring before approving home based businesses.
