1 members (Scott35), 442 guests, and 11 robots.
#100 11/25/00 01:16 PM
doc Offline OP
at a seperate building even if you run a ground with your wiring do you still have to install a ground rod at the seperate building
#101 11/25/00 10:25 PM
A grounding electrode system is always required at the second building unless it only has one branch circuit feeding it. See 250-32(a)
