Mounting the panel is required in some areas around here (local amendment). The idea being the basement wall is colder then the load center and could condence moisture. They say those ark faults get warm so the problem may be worse in the future. IMO panels mounted on wood tend to look cleaner after some years (little or no corrosion & etc.)
