iwire, where are the disconnects for those meters?
The Panels are all main breaker type located on the inside of the wall behind the sockets in the basement. The longest SE inside is about 5'
And is that se at the bottom of each meter?
Yes.
Don't you have to protect wire from physical damage?
That is up to the AHJ if they feel they are subject to damage.
These are not on a driveway so SE is generally accepted. If this was the driveway side the inspector would likely want PVC 80 or RMC.
This service as you can see is new, but I could drive down any multifamily street in most any city and town in MA, RI, CT, NH etc and take pictures of thousands of identical services.
As matter of fact here is the service he was replacing.
Notice the original services had
no mains.
Sorry for all the questions.
No problem, that is what this place is about.
We all do things differently, I know that all this SE is surprising to electricians in many areas.
