by NORCAL - 03/19/24 05:11 PM
0 members (), 255 guests, and 16 robots.
#100422 11/18/06 02:28 PM
Steve T Offline OP
iwire--since you brought up 406.8(C) in another thread, I read (D) and am slightly unsure what 'standpipes of floor receptacles..' means.
Insight please...
#100423 11/18/06 02:47 PM
Steve I really do not know.
I'll take a guess it is a older code rule for some sort of receptacle box supported on a pipe nipple out of a threaded floor system like walker duct.
#100424 11/18/06 02:53 PM
Steve, it could be something similar to the receptacle below as Bob mentions.
Roger
#100425 11/18/06 11:01 PM
How in the heck do you wire that beasty?
Larry C
#100426 11/19/06 11:56 AM
There must be some long wires trailing from the periscope.
Earl
#100427 11/19/06 04:30 PM
Larry and Earl, we found these in a university remodel. At first I wasn't sure either, but we found that they were mounted to floor duct through a nipple and the 1" RMC coupling that you see in the picture.
You can see the two screws that hold the top canopy on the fitting.
When the top is removed the devices can be wired (by the way this is a duplex receptacle, there is one on the other side too) and then the wires pulled back as the devices are fit back into their place in the fitting.
Roger
#100428 11/27/06 09:29 PM
Steve T Offline OP
If that type of install is what is meant, then my question is--
How high off the floor does a receptacle have to be mounted before it is not a floor receptacle?
#100429 11/27/06 10:14 PM
Beats me.
Roger
#100430 11/27/06 11:06 PM
IMHO If it's not in the floor then it's not a floor receptacle. If I'm the inspector, I'm just like the umpire- is it a ball or a strike, is it a floor receptacle or is not a floor receptacle.
George Little
#100431 11/28/06 07:01 PM
And to think I tossed about 12 of them out!!!
Should have saved at least one, but alas...to late.
As to floor recept...I doubt it.
