by ale348 - 03/29/24 01:09 AM
by NORCAL - 03/19/24 05:11 PM
#100139 10/21/06 06:30 PM
jersey Offline OP
What does the exception in 314.22 mean?
#100140 10/21/06 06:42 PM
It mean you can come out of a box cover with a flexible wiring method without installing an extension box on it.
The cover must have mounting holes like a device cover, it can not have key hole slots or regular slots in it like a 4" sq or round blank does.
#100141 10/21/06 07:11 PM
jersey Offline OP
Thanks , I was looking for an out for a problem I have. We installed some plastic fs boxes in a concrete pour. Not realizing that they were putting marble on these walls . Now my fs boxes are about 1 1/2 inches back of the finshed stone. Tried using a handy box collar but it doesnt cover the whole box. About 1/8 inch gap on each side. any ideas ?
#100142 10/21/06 07:30 PM
plastic goof rings
Correct me if I am wrong, I am here to learn
#100143 10/21/06 07:34 PM
jersey Offline OP
they make them to fit in a fs box
#100144 10/21/06 07:39 PM
I am not a fan of plastic so I use these.
[Linked Image from hubbellcatalog.com]
Add-A-Depth Ring
#100145 10/21/06 07:57 PM
jersey Offline OP
Seems like those are only good up to 1 inch. And do you have to ground them? Can you use two of them together? Questions and more questions sorry
#100146 10/21/06 08:16 PM
Not sure they are listed for multi gang use.
I have never seen anyone specifically ground them.
They end up grounded by contact with the yoke.
#100147 10/21/06 08:59 PM
I have heard a lot of yacking about extension rings and nobody has come up with a real reason that you couldn't gang a dozen together. Just watch your conductor length. You still need 6" at the edge of the last ring. In the ceiling of the great room of the Ca-D-Zan there are a buttload of 3" rings to get them from the box in the structural ceiling down to the finish of the antique mohogany ceiling we couldn't touch.
#100148 10/23/06 06:24 PM
Z
I've got a reason for not using a dozen extensions in an installation.
I was rewiring a beach snack bar in San Clemente a few years ago and they stacked 5 extensions into a block-and-plaster wall, with the conduit and wire coming into the deepest box. Although I agree that it may not present a safety or fire issue, I can tell you that re-pulling that wire was no day in the park.
