I just looked at a job at an Army base. They are rehabbing 2900 units. The work involves removal of the old switches, receptacles and replacing them with new and adding GFI's where needed. The ceiling fixtures will also be replaced. All matls are supplied by the base. Cleanup is not part of the work either, just strip, replace and move on.
Any thoughts on a per opening price? The work may get split between contractors. The pay is supposed to be at 30 days.
Any caveats? I already warned them about the possible problem with the luminaires and the old wiring regarding temperature constraints.
This is in MD.
TIA
TIA
