Can you run PVC for residential pool wiring for the pump motor and Pool light? I have always seen wrapped ridgid, unless you can convert to PVC once deep enough.
Also, why do they always use copper pipe to run to the pool light itself
The Golden Rule - "The man with the gold makes the rule"
