Have 2 50 hp motors in air washer. I`m adding inverters to them. Can I run from the disconnects to the cabinet and have both inverters inside with differnt feeds? As long as I label panel as such?In other words I`ll have 2 diconnects on wall feed from MCC panel now I`m adding a hoffman enclsure putting 2 drives inside with 2 breakers and bypass contactors and I`m feeding from 2 diffent disconnect into the one box.Guy here says its not code compliant but can`t seem to locate the code issues.He says must have single feed for both motors please leave some references I`ll go and read. Thanks
