Dave,
I suppose some areas on the exterior are not considered wet areas, like tight under a soffit.
Then why shall it be arrainged to drain?
If there is enough condensation to drain, it's wet.
If it's raintight, does it not need to drain? I would say there is a better than average probability for condensation inside of a raintight installation, wouldn't you?
Roger
