Take a look at the following mounting examples of recessed low volt lighting.
http://www.heralighting.com/mount.htm http://www.heralighting.com/info.htm 411.4 Locations Not Permitted.
Lighting systems operating at 30 volts or less shall not be installed (1) where concealed or extended through a building wall, unless using a wiring method specified in Chapter 3, .....
The installation requirements of 411.4 recognize that shock and fire hazards still exist, even with low-voltage systems.
How would you do this in a chapter 3 wiring method in a type 1 TOC?
Conduit, MC, Flex... Where would the connections be made?
Would chopping off the little connectors that on them invalidate it's listing? (UL 153)
Would any splices you made be required to be in a box?
[This message has been edited by e57 (edited 07-01-2005).]
