I only work under 200amps and all in copper, and for that work the wrong torque will not cause any long term damage
Doing Infrared Testing I come across many copper connections under 200 amps that are overheating from torque problems. When the insulation is breaking away from the conductor don't you consider that long term damage? Also like iwire has stated it is a code violation.
Al
