If you replace the overhead service entrance cable and the meter can on the side of a dwelling because of corrosion, would you also have to bring any service grounding into compliance to current code.Like installing suplimentry ground rods?
Also would changing the outside part of the service mean that you should bring any part of the inside service equipment into compliance with current code?
shortcircuit
