Hi,
Just took a masters test today for Arkansas and there was a question on the test that I couldn't find the answer to and was not sure about. Please read the following question and see if you recognize this article.
"Which of the following if made from an Insulating material shall not require a box for exposed wiring:
A)Switch
B)Receptacle
C)Tap
D)Wire Nut
I was not even sure where to look for this one. I guessed "TAP".
By the way, I scored 82%. 60 questions, three hours open book. 2002 code.
Thanks for any replies.
Mustang
