My two cents:
There are many different types of steel and coatings. If you are to believe the manufacturers, modern zinc-aluminum coatings give steel with very long life in ground. If you don't trust these, there's slow rusting steel. Unlike stainless the surface will soon rust, but as the layer of rust builds up, the process slows to a near halt.
