What the code on the following : I have a 400 amp base mounted on the outside of a single family dwelling with a 200 amp service panel mounted on the nearest inside wall, I also have a 200 amp 3r disconnect switch mounted besided the meter base for and out building and it is labeled. Is there a code problem?
[This message has been edited by elk45/70 (edited 01-03-2003).]
