Yes, the section does require expansion joints, but only where necessary to compensate for thermal expansion and contraction. Just because the raceway is exposed to different temperatures does not mean an expansion joint is required. You have to do a calculation based on the range of temperatures and the coefficient of expansion to determine if an expansion joint is necessary.
Don
Don(resqcapt19)
