Table C1 allows you to put 4- 1/0 XHHW's in 1-1/2" EMT. If you look inside of a (Red Dot for example) LB it is marked with the cu in. capacity AND " MAX 3- #1/0 XHHW or EQ." Does that mean the pipe size must be increased if you need to use one of these conduit bodies?
