'66,
You actually got an Allegheny Power Company employee to commit to something? Mark it on your calender, you're not likely to see it again in your lifetime.
As other posts suggest, bonding can be at either end & the panel side is usually easiest.
Be glad you aren't in Clarksburg. The AHJ was (at one time) insisting on a 3rd ground rod because the nipple between the meter socket in panel was PVC & there was no bonding bushing.
Swear to God!
Tom
